Bob Ayers
North Carolina Chapter member
Hey Ian, on that note... I was thinking of going down and grabbing a cheap PA just so I could play with the radio until the antenna comes. If there is no antenna attached, in PA mode, and you key up... The signal goes straight to the speaker and doesn't get transmitted over the CB? As in-- no damage done if I key up the PA with no antenna attached?
CB radios are AM (Amplitude Modulation), and the audio power amp in the CB either modulates the RF carrier at the RF output stage (CB mode) or is fed to an external speaker in PA mode. In PA mode, the CB is nothing more than an amplifier. So, keying the mike in PA mode will not hurt the RF output stage without an antenna. As far as fixing the feedback problem in PA mode, position the speaker so the sound from it doesn't reach the mike, and this will
fix it.
