Working on the brakes
I bought new "boots" for the '89 today, all around.
The brakes would lock up by just looking at them. I pulled one of the rear drums, and the wheel cylinder was pooched, and completely saturated the brake shoes. New pads on the front and new shoes on the back, and a good cleaning and bleeding should cure the problem.
Haven't looked at the rotors, but the drums are worn very little. I'll have to clean all the fluid out of the drums first, but at this point, I don't think so. It will mean an 80 mile trip to get to a shop that will turn them
My parts guy gets drums for like 20-40 bucks each, generic rotors are usually between 14-25 also.
I'm hoping I don't have to replace the drums. Aren't the drums for 3" brakes a little more spendy than that?
Looks like they sell "flange mount" and "hub mount" drums for the rear. What is the difference?
Flange on a floating axle maybe ?
I don't know, Mark. The parts website shows both types of drums for 3" wide brake shoes, which I think are for the heavy duty axle?(full-floating)
Got the left rear brake shoes replaced today, which was the one with the pooched wheel cylinder. I used a rebuild kit for the cylinder, figuring that the original cylinder was better quality than one I could buy at a parts house. It took two cans of brake cleaner to get all the brake fluid and gunk out of the drum/backing plate. The drum itself was in good shape with no ridges. I will sand them, per Roy's advice(thank you) and put them back on.
It took me 3 hours to do the job. Some of those spring retainers are pretty stout.
Do you have spring pliers Doug?...or were you using the normal creative ways to remove and assemble?
Yes, I have spring pliers, but the attachment of the shoe to the backing plate involves pushing a stout spring over a retainer to keep the shoe in place. It's a better way of keeping the shoe in place, but you have to have to have the muscle to get the end of the spring underneath the retainer. What can I say, I'm a pu***.
Even with the with spring piers they can be uncooperative at times.
I agree 100%
:rofl: :rofl: :rofl:
I use a vise grip on the shoe to backing plate springs, and the generic spring tool on the return springs. The drums are all slide on that I have seen.
That's what I've been using. I got the old ones off. I finally gave up on the passengers side for the night. It looks like the axle seal might be leaking on that side. :headbang:
I've found that a larger pair of vise grips makes a world of difference Doug, more to grab on to, fits the hand better, if that makes sense.
So, I guess I need a BFVG? :)
