Well its been running really rough and the lower TB coolant hose sprung a leak. Well I decided to spray some Carb clean around the intake it the idle changed, so i decided id do the upper to lower gasket, then change the rotted out valve cover, and since i was doin that id put some roller rockers on that I had for my mustang project, that I ended up not needing. Well I decided to use the smoke machine to ck for vac leaks, and the lower intake was leaking from where the intake bolts to the head. So then I had to do lower intake gaskets too, yea they were all pushed out and messed up.
SO to recap, I did the intake gaskets, upper and lower, passanger valve cover, roller rockers, thermostat, and she idles SOOOO NICE NOW
