won't start :/
so i set my timing and the truck was idling good. i was tightening the dizzy down and the truck just shut off. it didn't diesel or sputter. t just stopped. now it won't start.
fresh battery, alt, voltage regulator.
was tuned up completely in july/ august and carb rebuilt.
it hasn't ever done that. idk what is wrong with it.
Try attaching a wire from the battery + post to the + terminal of the coil
Don't leave it like past 30 seconds.
If it ran then you may have an ignition switch or resistance wire issue.
If not, grab a multi meter....
There are may tests coming if needed.
i will go through them tomorrow morning. when i get up. i hope its something stupid like a lose wire or something
Might be....lots of times things have been butchered by previous owners.
If it shut off while tightening the dist, I'd bring the #1 piston up to TDC and pop the lid on the dist to see if its pointed at the correct place.
It's a quick check to make sure the dist, didn't spin when you weren't looking.
i thought about that i will have to look this morning. that would be nice if that was the issue.
tiing is still on so thats not it. i did try to get spark out of the coil while cranking the engine still didn't get any. going to try the battery terminal to the coil and see what happens
