any idea on where i can get an engine wiring harness of an 88 f150 with pcm mounted on distributor?
any junker that can ship to belgium? or new would be better.
oops indeed missed in that one indeed the tfi module.
problem with the old wiring is that it's a huge mess wires cut and solder bad etc...
and when i put in the spout connecter i have no ignition left so i'm planning on replacing harness, pcm and tfi to make sure the car is reliable... already changed tfi once also the distributor pickup has been changed and the coil.
i was first thinking on changing it into a vacuum advance distributor but for keeping it more original i decided to keep with the tfi if i can make it work properly
