Can i put the rear end from an e250 onto my f150? the van is a 92 i believe and the truck is an 86
Thanks Joe
Thanks Joe
oh the other thing is...is the truck 4wd?? because if it is you have to make sure the front axle and the rear axle have the same gear ratio
no, th ef150 is only 2wd like the van. How can i tell what axle it is and the gears?
What about 9" rear diffs?Mine has no such tag.I decoded mine by the Door sticker.or you can check the axle tag on that should be attached to the rear diff cover on one of the bolts. it will say something like 3.55 or 3.08 something to that effect
Thats what she said...will it fit?
Tyler,thanks for reminding me about my crappy 2.75 gears.
Worst gears to have in a truck.I can't wait til I get some lower gears for it.
pretty much the only way to check for an LS axle is take the diff cover off and look for the clutch packs.
its weird... im ny truck it says i have open 3.55s but i just did a sick nasty burnout and i lit up both tiers...
1959 thru today cars/trucks:the van rearend i have says it is a 24. that makes it a 3.73 but not a limited slip like i thought, but im pretty sure that it has limited slip... now im not sure anymore
