Will a bumpside body fit a dentside frame?
5.0
FTF'er
1,319
64
In the Middle
I have a 77.5 F250 4x4 standard cab long bed with a trashed body.
There is an old 2wd bumpside, uncertain of the year, sitting in a town south of me.
Will the bumpside body swap to the dentside Ford frame?
nobodyspecial
Fire in the hole...
5,756
366
ND
The cab will bolt right up, but there are frame differences in the back that need to be taken into consideration to get the bed to mount up correctly. If just bolted on, there will be a large gap between cab and box. Some people move the cab and axle all the way forward to fit right. Some people center the box between cab and rear axle, so its slightly bigger gap, and the rear axle is slightly off center, but its not very noticeable. Check on Fordification, there is a writeup I believe.
FTF'er
1,319
64
In the Middle
Ah, so the older truck is a shorter wheelbase? I never even thought about checking that. I would probably mount the bed as it should be against the cab and then move the rear axle forward some... if I follow you post correctly.
I'll check out the site you referenced for more information, thanks!
nobodyspecial
Fire in the hole...
5,756
366
ND
Yeah, but I read on that site that people have just centered the box between the cab and the rear axle, and the difference is negligible, its pretty hard to notice, I guess.
5.0
FTF'er
1,319
64
In the Middle
Yeah, I'd have to try it first and see how it looks.
