What will hook up to a 351 Cleveland
12
I found a good deal on a 351 set up for drag racing already which is cheaper than rebuilding my 390 will a zf bolt up with some conversion
The Clevelands share bells with the 302 and 351W, so as far as bolt up goes, those would Flywheel would be my one concern trying to get a ZF on it. I'm sure there is a way, but it won't be a direct off the shelf option probably. Not sure what the crank bolt pattern and balance is in comparison to the 302 or 351W.
1970Custom
They call me Spuds
14,107
447
Middleton, ID
ZF is a 10spl input shaft IIRC. So the Cleveland clutch should work.
Next issue to resolve would be the hydraulic clutch setup, there is no fork on the ZF for small blocks...
I was thinking the pedal end, but that end also needs checked.
If you are bracket racing, sure.
There is hope for you yet :p
I haven't known ZF's to be fast to shift. I have however, known the shifter to break off...
