What did you work on today
heavydoc
Instigator
70
WNC
I'll see if I can find some, although I don't know how to link utube videos [emoji848]
Blue-Truck-Nut97
crank polisher
551
18
Open the video, hit the arrow ( share) button, copy, then paste the link in your post.
I just watched a couple, baking soda and water was also used. Really cool process. Just don't zap yourself......
When I was a kid we had a battery leak on an oak trailer floor, we put baking soda/water over the acid to kill it, anywhere the acid/soda reaction happened stained the grain a vibrant purple. But I've never been able to duplicate that.
heavydoc
Instigator
70
WNC
I found a few on plywood, but the ones I saw before were on 2x4, 6, 8, 10's... and were very cool looking. Not real impressed with the baking soda yet!
See the red square with the word 'tube'?....click that and copy the video ID between the '=' signs.When you click on the that this will show up....paste that number between the 2 sets of brackets
heavydoc
Instigator
70
WNC
I'll try that when I find one worth a crap, thanks
heavydoc
Instigator
70
WNC
Made a jig when I got home and remade the inner ring, alot happier with it now[emoji16]
heavydoc
Instigator
70
WNC
It looks like I'm gonna doc engineer this whole phuckin thing[emoji2959][emoji2959]
heavydoc
Instigator
70
WNC
Back to the equipment side of things. Went an worked on a JD CT332 skidsteer. Complaint of the parking brake won't release. I ended up finding the engine speed sensor was broke from SO MUCH DIRT BUILD UP from behind the fuel tank, that it broke the mounts and pushed it into the sensor. Spent all morning breaking up the frozen dirt to move the tank back.
heavydoc
Instigator
70
WNC
Then went to a JD 844K series 3 AR with SCR codes. Took me a few hours but found the def dosing pump that I put in a month ago was bad. Figured out the def tank vent was plugged causing the pump to work way to hard and were itself out[emoji1787][emoji1787][emoji1787]
heavydoc
Instigator
70
WNC
Got a 2554 Deere tracked log loader trying to figure out weak hydraulics on[emoji848][emoji848][emoji848]
Installed a handicapped toilet for my Dad. Been working to get his house more elder friendly for him.
Been doing the same for the wife. Lots of grab bars for baths, showers, etc.
Spend as much time with him as you possibly can.
You wont regret it
YelloThumbUpYelloThumbUpYelloThumbUp
heavydoc
Instigator
70
WNC
Good times, I really thought the frame would have been painted blue by now[emoji848]
heavydoc
Instigator
70
WNC
I tested track cycle times on that 2554, spec is 3 revolutions in 30 seconds in low speed. It was 22 seconds for each revolution [emoji53][emoji15]. The pumps are shot or someone has really phucked with the pump regulators. All pressures are half of spec and cylinder cycle times are double the spec. Meaning low flow and low pressure. [emoji857][emoji857][emoji857][emoji857]
Blue-Truck-Nut97
crank polisher
551
18
Way to go Doc! Looks like that's gonna be a mess.
Still fitting everything, going to fit the carrier and 5th wheel slide, and the bulkhead for the air lines, then it's all coming apart back to bare frame. Clean the cuttings out and zinc chromate everything, then final assembly, then paint.
