What did you work on today
smokey
Hitech hillbilly
Just worked on computers. Need to put a new tensioner on the Focus. Threw the belt off put a new one on and it tossed it. So I'm replacing the idler and installing a new tensioner. Got to lift the engine to put them on. Not enough room to get you hand to anything. It's going to be fun.
Output shaft seal and nut 9 speed fuller .
heavydoc
Instigator
70
WNC
Started building SWMBO a table for her puzzles, gonna suspend this one from the ceiling. Just not sure how I wanna do it yet! I'm thinking hang it with ratchet straps so I can start fabricating a cable winch system to raise an lower it???
A guy that used to post here m78 made a cool setup for raising and lowering his topper using a HF winch and pulley system I think, looked like it worked well.
heavydoc
Instigator
70
WNC
Thanks Jon, also built the inner and second ring of my picnic table, may rebuild the inner to fit better.... or use my air hammer to get it in there[emoji1787][emoji1787]
Blue-Truck-Nut97
crank polisher
551
18
Just soak the outer ring in the bathtub overnight. It'll swell up.
Of course when it dries out again results may vary.
heavydoc
Instigator
70
WNC
Thanks, it took me most of the day to get my chop saw set at 22.5 degrees. And to get a wood blade to fit my chop saw
Blue-Truck-Nut97
crank polisher
551
18
Hey Doc, are you planning on running along the joints with a wood burner when you are done? I think that would look really cool.
heavydoc
Instigator
70
WNC
I haven't thought about that, but I will try with it. I've got a few extra inner rings was thinking about making a clock with one. But I'll try the wood burning on one of those[emoji848]
Blue-Truck-Nut97
crank polisher
551
18
Was envisioning the large perfectly aligned spider web pattern, plus, it would camouflage any deviations from the saw blade.
Nice work!
heavydoc
Instigator
70
WNC
Nice work!
I've been thinking about trying my hand at burning some wood with salt water and an old microwave like in some utube videos I've seen. They come out with some really neat patterns
Blue-Truck-Nut97
crank polisher
551
18
Hmmmm, never heard of that, off too YouTube later.
I've used my soldering iron, wire heated with a torch, or a wood burner, and branding irons of course. All with some degree of success.
