What did you work on today
heavydoc
Instigator
70
WNC
I'm thinkin fuel pressure and high pressure oil.
Sent from my SM-N975U using Tapatalk
heavydoc
Instigator
70
WNC
I worked on Jezebel today. She is my 96 ive built from the ground up. My nephew is in need of a ride so he is flying in next weekend to drive her back to AZ. It had a weird problem with the horns going off when the washer button was pushed. And during troubleshooting found that the A/C compressor would also engage when the washer button was pushed. Come to find out I shorted some wires together when I installed the aftercooler. Now I'm trying to figure out the loping idle
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
fuel pressures on the top row... high pressure oil i can read through the icp sensor... not easy to get back to where that sits to tap into that one... im gonna do an inside outside temp gauge but gonna put that in the assembly i have for the steering wheel... but need to get that to see if itll even fit in the holder... found out with a prior gauge despite it being from Autometer it didnt fit an autometer gauge... (the mounting screws are too long to fit in the hole..) and the glowcrap gauges didnt fit either...
technically i have 2 fuel pressure gauges... one electrical the other is mechanical mounted on the regulator... need to get some glycerol to refill that gauge... it sprung a leak...
lol my mustangs named Jezebel... shes an 04... lol
heavydoc
Instigator
70
WNC
Sadly the engine went south in Jasmine, my 02 CCLB DRW
heavydoc
Instigator
70
WNC
I thought about that for half a second but then thought it would be best to do a brick nose with a Cummins. But still have a hard time with that. Its blasphemy
heavydoc
Instigator
70
WNC
I'm rebuilding the 7.3, as God intended it to be
heavydoc
Instigator
70
WNC
Got the engine out and cylinder heads off. Cylinder walls don't look to bad, gonna put a hone to it and see what it does
heavydoc
Instigator
70
WNC
Been awhile since I've updated this.
Motor mounts on a 160D. These 2 against the counterweight weren't to bad, but the other 2[emoji2959][emoji2959]
The Southern President
heavydoc
Instigator
70
WNC
Got a big job started at the beginning of February. Put together two 470G Excavators and a 950K crawler. Waiting on a 670G and an 870G to show up. Gonna need a crane to put those 2 together though!
heavydoc
Instigator
70
WNC
Started building a new gun stock for a Lil 22 I picked up that the previous owner really f@cked up.
heavydoc
Instigator
70
WNC
And for those wondering what was wrong with the engine in my grey truck! Still haven't figured out why anyone would have done this
