What did you work on today
heavydoc
Instigator
70
WNC
Looking great, those are the same wheels on my Excursion, salt pits and all..... Charlie are those my Excursion wheels?
Sent from my SM-N975U using Tapatalk
3,298
191
In my own world
Um. No. I actually think old skool muric acid, wash, then polish out wit my homemade polish
Here's tank on owmbo's Pete I did a bit back
heavydoc
Instigator
70
WNC
Fan drive hub bearing replacement on a 824J JD quarry loader
heavydoc
Instigator
70
WNC
Took me a bit to find this one, that harness runs through the articulation section of a 544L loader. It is fully covered in a protective hose layer. Cut the hose off and did a 10 lb pull test on the 39 wires in that harness. 30 of them broke. It only had 1 code and was intermittent
heavydoc
Instigator
70
WNC
Pulled the cab to replace the internal transmission harness cause the transmission temp sensor was reading very hot. That sensor is made into the harness
heavydoc
Instigator
70
WNC
This was a fun one, at the top of a sand pile and threw the left track off to the inside on the sprocket and idler end. I was there to fix a hydraulic thumb issue. Owner was pissed when I told him about it. The trackhoe wasn’t even supposed to be up there. In fact the operator was told specifically not to climb the pile
heavydoc
Instigator
70
WNC
They aren't so bad, the 744's have a ton more room around the engine to work on
