Wanna beef up susspension
I have a 1990 f 150 that I am currently swapping motors on. The truck has 437 k orig. Its a 4x4 would I be abel to put a 2 or 350 front coil springs in without having to worry changing any thing for allingnment issues. The truck plows a lot and is used for a lot of towing. So dont wanna go aftermaket.lift do to truck having tow package / helper springs in rear.
Thanks greg
If you use coils from a 2wd F250 or F350 it is going to lift the front end a little bit and you'll end up with this \---/, so you'll need to put in some adjustment shims. It's not that big a deal.
The other thing that you'l have to contend with is lifting the rear to match-- unless of course your truck has a raked stance right now (high in the back).
smokey
Hitech hillbilly
For the front for plowing I always put airbags on. They fit inside the coils and help absorb the plows weight.
For the rear a extra spring ply should help stiffen it up.
^^^That's the route my dad used for years on his plow Broncos.
I have thought about the bags but I was looking to level the truck out do to the springs in the rear already have 2 xtra leafs and the truck has a towing package.so would I be able to get any lift out of bags or would I have to put some leveling blocks in it.
Well one coil broke the last time it plowed and when I blew the inlin sky high so im going new fronts. But just waying the options but ive been locking at prices and they aint as bad as I thouhht they would be.so prolly gonna end up bagging the front. Thanks for the help and the idea.
Lost
PA Chapter leader
3,288
central PA
If not plowing go with F350 2wd drive coils and be happy plowing go both
