fourwheel
fourwheel
I haven't put the full six quarts of oil in my 1996 351 since the first oil change. Had to drain over 1/2 a qt. to bring down to the full line. A friend with an F150 (same engine) was told he had to use the full 6 qts. or damage would occur (his is over the line also). He uses the same short filter I have to use. Since the first oil change, I fill the filter the amount that wont run out while turning it on usually about 12 oz. and save the rest of that bottle, then dump 5 qts in the crank case bringing it up almost perfect with the full mark after its been run a few minutes. The manual says six quarts and don't fill above the full line on the dip stick. I say its in the filter capacity and not what the owners manual says to dump in the crankcase. Any opinions if the dip stick got stamped wrong? Or won't 20 oz be overfill. Oil has been synthetic and changed around 3-4000 miles.
fourwheel thanks you.
