flareside_thunder
- 7,812
- 246
The other day...Tony knows cause I called him..My truck got a little warm....it went past the L on NORMAL for these crappy idiot gauges. NO I haven't hooked a mechanical gauge up to her yet to see actual temps, although you can definitely hear it boiling and know it's hot. NO I haven't hit parts of the cooling system with a thermogun to get a relative handle on things and where the issue may be.I may however, do that tomorrow. I do know I just bought a new T stat and it didn't seem like it was opening so I pulled it out and put nothing back in. Along with that I've replaced my fan clutch with a newer used one but it was actin funny and had me worried so the old girl got a Flexalite fan with a 2 1/2 inch spacer. In addition to that she also got "Water Wetter" and one gallon of straight antifreeze with the remainder onf the system filled with water AFTER I thoroughly fluched the radiator and block out with fresh water...Letting the truck cool down for a few hours of course. I finally got to drive it at night so I'm still a little finicky of the situation as of yet...not having driven her in the heat of the day. I also learned that pulling the hood off with bring underhood temps down by two whole letters...once again on the idiot gauge. I am relatively sure it's not the pump also since I had the cap pulled and revving her up she shot water up and out a good foot and a half. Elvira...why be so cruel to me???? I did like every other frustrated truck owner does and threatened to trade her off...I've already got my eye on one too! Anyways..any other thoughts or comments are greatly appreciated...I need to bounce these symptoms of some other heads for a bit and see if I can't get somewhere. Also, I checked for any seepage from gaskets on the timing cover area and saw nothing...There are also no other fluids mixed with each other. I also threatened to blow her up and drop a 6.0 in her...my buddy said he'd help me fund it and do the swap....heh I found the engine tranny and harness for 2500 bucks on a 120k engine.....
