transmission swap
Changing from what? If you have 4wd, you will need 4wd transmission unless you are doing a divorced case.
He could swap out tail shafts too, couldn't he? If going from 2wd to 4wd and vice versa, that is.
If he had all the parts to do so, I'm sure it could be done, but if I read it correctly, he is coming from a different trans altogether...
