transmission help....
Hey guys/gals..new project vehicle for me. I recently replaced the clutch on my 1977 250 highboy..and am having problems reassembling..put it back together and when you let the clutch out it stalls..stops dead.no turning of the transmission output shaft..the manual said to remove the gearshift housing for removing the trans and replacing the clutch..I'm guessing its not in neutral when I replaced the gearshift housing back on..manually slid reverse and first gear around and got it to spin..but only with the clutch depressed..can't seem to find neutral with the gearshift housing removed..I know it needs to be in neutral when I reinstall the gearshift housing.. Any help ideas.?
When you look inside, the shift fork rails should all be lined up in a row, no stair stepping.
