trans question
That sounds like a seperate issue to me. Have you tried adjusting the neutral safety switch to see if the backup lights work?
well today the truck started and i drove to the store then when i restarted it , it wouldnt go into reverse without heavy bucking and it slipped in first gear and didnt seem to want to go into overdrive so i dropped it at the shop chapter two starts in the next day or so when i get the diagnosis
Fordzilla80
Ranger Lariat
6,372
262
Narnia
Bucking? You should have a 4R44E if I recall correctly. There was actually a factory recall for this problem. My old Ranger had a similar bucking from 1st to 2nd gear. I'm not too sure what the fix was, or if that's even your problem, but you could look into it if you want.
well the trans shop told me the reverse band was bad and apparently the third gear one wsant too swift either... they replaced the neutral safety switch and apparently the overdrive switch is acting up ( one on the column) and they need to look at that cause when you put the truck in reverse and the lights come on then suddenly the fuse for the overdrive blows and then i lose the reverse lights... so i wont see my truck until after the holiday
Did they fix it yet?
