Did it. But it was raining to hard to be able to finish, so I'll finish up this afternoon.
Afraid you were gonna melt?
Afraid you were gonna melt?![]()
Do ya have vacuum goin to your vacuum advance? Also try to suck on it and see of the pressure bleeds off if it holds the diaphram inside is fine.
Hey fellas...I apparently just can't win. Today on the way home from work, I smelled the gas again and a reeeeeeal bad stutter, which I thought was a carb issue previously stated in another thread. Well, driving to the gf's house, the Bronco seemed like it was on it's death bed...acting like it jumped time...again. Sure enough, I get a light on it, and it was advanced about 25-30* further than I set it. If you recall, about a month ago, I replaced the timing set with a new Comp Cams double roller set...but wasn't thrilled with the quality. I doubt any teeth broke or the chain stretched over the course of a month, but I guess it's possible. So what are the other possibilities? Sheared dizzy gear? But I didn't figure I'd be able to get it resarted if that were the case? Cam bolt backed out? Didn't think it would hold a consistent time then? Any other ideas or suggestions for me? Thanks in advance.
How much space is there underneath the ICM ?
There should be about a 1/4" for air flow to cool it.
