Good tip with the loctite. Never even thought of that before.
RE-install it and lets see what happens![]()
When the gears line up it shouldn't move. You can't drop the distributor in with the mark lined up. It has to be off a little bit so when the gears do line up the rotor spins into line with the mark you made.
Use Finesse.
You never disturb the engine ever if you have serviced the dizzy.
Align the gear timing marks to each other, reassemble and DON'T move the crank when installing the dizzy.
20* is 1 /18th of a turn and that can be acheived by turning the crank very little.
Ben,Have you inspected the roll pin that indexes the reluctor(armature)to the distributor shaft?They sometimes try to shear,or develop slop in the reluctor and distributor shaft keyways.Every half tooth off that reluctor is out of phase with the mag pickup stator is 8* of ignition timing.The cam drive gear usually does not create problems with the distibutor installation,but the oil pump driveshaft can be a pain.You can turn the pump shaft with a 5/16 deep socket,extension,and ratchet.I use a 1/4" setup.It is a turn and check procedure.Be patient,when everything is aligned it will slip right together.Have you checked the operation of the vacuum advance?Make sure everything is free and not binding or sticking.Sorry for the long post.Hope it gives you other things to inspect/repair while you have it opened up.
Make sure you duct tape that 5/16" socket to the extension or you risk it falling into the oil pan.
