F 150Cobra
"Wild HoRsE" Got Torque?
the gt40's head and cam looks like an good idea
with headers
underdrive pullys and you will be happy
an idea's on a cam ?
i recomend this
http://store.summitracing.com/partdetail.asp?part=CCA-35-351-8&autoview=sku
ntake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Lobe Separation (degrees): 114
note: you will need a maf upgrade for it to work properly
with headers
i recomend this
