It should be ~190*.
I have heard that ~180* works better.
Tongs =
If your truck is running cool then it shouldn't be a faulty t-stat..usually when they fault they lack to open...I have a 180 in my truck...the needle does not move from the line right before the Normal area...it'll raise then I can watch it go down as the stat opens.....stock is sposed to be 195...I wanted something cooler...but that's just me.Also, most of the time when you have a bunch of air the truck will run hotter not cooler.
