So it Begins F350 Camper Special Rebuild
Looks like it is in pretty good shape, whats the plan?
76
2
Assessing it now looks like I will take bed and cab off and rebuild. Been setting in a wood board garage for 10 years or more. Runs well some surface rust underneath 80k original miles motor runs no smoke. Not into add on will keep it stock looking. Will update as I go along.
Cool, looking forward to seeing your progress smilieFordlogo
I am looking forward and I will be very interested in your thread and what you come up with Jssec, as someday I hope to give my 76 Camper Special a rebuild also. :)
76
2
Work In Progress day 1 of ?
Found this in the carpet I took out do not see them much anymore. https://www.dropbox.com/s/8irzwcy4x0v20d8/2013-12-29 17.02keytag.02.JPG
Also found the original Owners Manual in the glove box. https://www.dropbox.com/s/3j1cu87oaa1k68f/2013-12-29 17.15.39.jpg
Got the inside stripped ready for my body/paint guy.https://www.dropbox.com/s/bxqtejgnoi7sjnl/2013-12-28 19.07.00.jpg
Stripped inside of the doors will coat inside after through cleaning.
https://www.dropbox.com/s/7e1op81lmv7x0y0/2013-12-29 17.23.27.jpg
Stripped all the weather stripping and glass rattle stop will replace after painting. https://www.dropbox.com/s/by6nwqet791r3kq/2013-12-29 17.23.41.jpg
Truck bed will come off later this week to fins fuel drip or may need to replace tank.
Taking the window regulators out?
76
2
Sand Blasting F-350 CS today.
Took couple hours to blast the back frame and the under side of the bed. Used 100# of blast media I give the $100 Harbor Freight Sand Blaster a "Thumbs Up". Took all the old paint,flaking rust and dirt off. Don't see the need to clean it all down to bare metal. Will remove the wheels and drums and clean the backing plates. It also took all the rattle can black paint off the air cleaner hosuing.https://www.dropbox.com/s/c1m1s7rosb8kb12/2014-01-09%2018.31.30.jpg https://www.dropbox.com/s/sxlyltedlp8h5o2/2014-01-09%2018.31.53-1.jpg https://www.dropbox.com/s/xdsk0d9pdg6zrpr/2014-01-09%2018.31.42.jpg
76
2
Left Hand Wheel Studs?
Owned a lot of F350's (12) starting in 1970 thru 2008 never ran across a left rear wheel that had left hand threads. After a few tries with the air gun to remove lugs upon further inspection this 1978 F350 Camper Special has left hand studs marked with and "L" on the end of the studs on the drivers side. Check out the owners manual and it does not mention it has "L" Studs.
Can't see pics...Dropbox has crashed :(
