- 112
- 0
Just failed my smog test on the 79. Everything was a pass except the CO2 which was way out of whack. Gonna have to start backtracking. This is a 460/c6 CA vehicle all the smog is intact after reinstalling what was laying there from the PO's handiwork. Carb was just rebuilt, vacuum lines all replaced, timed to 14 deg. as per the under hood sticker. The smog guy just read off a crap load of stuff that could be affecting it. Where to start boys is the ? Am I to understand that it is getting to much fuel and not enough air, is that right? I did notice the the flapper on the air cleaner is not opening when motors already nice and hot, I know the flapper works cause if I remove the vacuum hose it slams shut remove it and it opens. I am thinking that small sensor whatchumacallit under the cleaner that has vacuum to it might me the culprit, if so could it be the cause of the high CO2? What else can I do to get this to comply. Also changed the oil , plugs, filter, no additives just in case, anything else? What sensors(you know what I mean) valves should I be looking into as culprits and are they still available over the counter. Damn I thought I had this taken care of.... Help!!!!!
