- 1
- 0
i can't find anyone who can actually tell me how to bleed the slave cyinder on my truck...its a 1994 f250 7.3 with the 5 speed transmission..can you guys help me
Mine bled itself....tell me how to bleed the slave cylinder on my truck...
But remember to unstrap it when you have it in place... I broke mine because I forgot to, so in the future, it won't be able to strap back.well there is 2 types of slaves you can get. being a 5spd 7.3 you slave is external, not internal like shown.
If your lucky you got a slave with a bleeding valve. which would be like bleeding a brake for a car or truck.
If yours doesnt. You will have to "bench Bleed" it...
When i bench bleed mine, I put it in a vice on like a 30deg angle, with the piston pointing down. then fill the slave with fluid and pump the piston, fill again, pump some more untill no more air comes out. Once your done that carefully install it onto the truck. And remeber to keep that plastic strap on the slave when you install it.
