Rumbling when releasing clutch from start
Checked my motor mounts tonight and the bolts were tight.
Hi Steven - does your truck have a two piece driveshaft - if it does there will be a centre bearing bolted to a chassis crossmember which you could check out - if its bad you should also be able to hear a rumbling sound while driving at a moderate speed.
I would continue back down the drivetrain checking the universal joints , shackle bushes, - anything that could be loose etc.
Cheers Mark
wareagle
War Eagle
1,935
40
Hickory, NC
Cheers Mark
Will check that out Mark. Thank you again to you and everyone for their advice.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
D9TZ-4800-A .. Driveshaft Center Support Kit / Available from Ford.
Applications: 1961/79 F100/250 / 1975/79 F150 / Misc 1980/89 F100/250's.
Kit includes the bearing, U shaped rubber support and bracket, shims.
MSRP: $96.83 // PARTSGUYED.COM price: $69.72.
wareagle
War Eagle
1,935
40
Hickory, NC
Thanks Bill.
