Replacing tie rod ends
Id just ask the shop to lube it up, you will need to fill the boots up after you install. Can you believe factory ford stuff doesnt have fittings, y do you think econoline and f-series ball joints fail at 30K. Just had a van in today. 99 E-250. 31K ball joints wasted. Should have put some fittings on. Its easy you will have no prob with it. Shift kit got to be like 1000x harder then tie rods.
663
So it's all done but we got trouble.
I forgot to measure the distance to the sleeve and instead I counted spins when I removed the old ones-- bad idea.
Trying to get the ends to match up and fit into their sockets didnt work out well so we winged it a little bit and spun the joints around until it looked about right. No good. I backed up in the driveway and then pulled back forward, giving the steering a little bit of movement, felt really weird. Got out-- passenger tire is JUST about straight, and the driverside tire is turned significantly to the right :headbang: And the tires now look like this \-----/
But I'm assuming the toe out is because the misalignment of the two tires was pushing the bottoms together :headbang:
So whats the best course of the action? I think the sleeve that we fudged with more was the left one. I'm thinking-- jack up the truck, loosen the left sleeve and rotate her around a few times until the left wheel looks sorta straight? Am I thinkin' right here?
radialarm
Clown of Death!
HAHAHAHAHAHAHAHA!!! Your killin me here, man.
Try to get the thread count even on either side of the sleeves. keep the steering wheel straight then use a tape measure to get about an 1/8' toe in and get it aligned tomorrow.
Mr. Stroker
CASE IH
3,121
67
Michigan
i recommend un threading and lifting the truck up, make some chalk lines, or eye it up, try to get it as close as you can. No long trips to the alignment shop for you now.
663
Huh? Can you be a little more detailed in what you mean. I'm confused by "1/8' toe in"...
Unthreading what? You mean backing the sleeve off a bit to push the left tire out? And what about chalk lines?!
Please be very clear with your posts... I'm not experience with steering components or terminology.
Brian_B
blank
1/8" toe in. Measure the center treads of the tires...front and back. The front side should measure 1/8" less than the back. That is how we align the old trucks. That and the degree shims I spoke to you about a while back.
radialarm
Clown of Death!
Measure from the back side of the tires to the front side and get the front side about an 1/8" shorter than the back.
It sounds like you got a mess and the worst thing you did was moved the truck. Just try and get them aligned as best you can to drive it to a shop tomorrow they shouldn't charge you extra to fix it.
663
Ah okay. I don't have a tape measure :headbang:
Brian_B
blank
Modern front ends are a bit mor epicky with allignment, but that is all they did to the old trucks. If it wore or drove funny...they would move it a bit more one way or the other. Same with the shims..2 degrees was swapped out to a 4 degree shim if needed after driving them.
If you can get it close...then take it to a pro to get it alligned. From the pics...you have issues. Drive it to the shop only. Do not pass go and do not collect $200.
radialarm
Clown of Death!
No just blew the old alignment points nothing major
radialarm
Clown of Death!
Sitting still the tires were still aligned somewhat. If the tierod ends would go back in without having to move the tires you would pretty much keep the old alignment
663
Yeah I don't plan on driving it anywhere beside DIRECTLY to the shop.
So game plan for tomorrow morning--
1) Put front axle on stands
2) Loosen clamps on left sleeve
3) Rotate sleeve so that left tire turns back towards straight until the front of the tires is 1/8" skinnier than the rear.
4) Tighten clamps and drop it back down?
663
Yeah I gotcha. Problem was that the tie rods wouldnt go back in without adjustment since I forgot to measure from the sleeves to the joints :headbang:
radialarm
Clown of Death!
Not being an experienced front end guy you did pretty well mine was not right either. so take it easy.
