rear end
'93 F350, w5spd, u joints replaced last summer,
i can hear clunking when rolling in nuetral, rear end on it's way out?
i replaced the gear oil last month with fresh 80 weight n Lucas Oil Stabilizer.
any recommendations on a good LSD?
I have had the pinion nut work loose more than once... Snug it up and off we go.
3,291
188
In my own world
Agreed.
Maybe add a new seal if it's leaking at the same time.
thanks guys!
took it to mech. to check he advised u-joints we're bad, n replaced the year Napa ones.
took it home n my transfer case bound up, stick between 2 hi n 4hi, (needed 4wd to get it parked in the back yard), back to mech he found no issues, lubed stuff up, it's better but cant get into 4Lo now... think maybe I left it sittin unused too long?
3,291
188
In my own world
Take the shift tube off, sand, and clean THEN lube
It will easily break, it's only pot metal, and they are HARD to find
shift tube? ��
