Ranger Windshield Wipers Quit Working
Jolly Green
I Salt My Ketchup
755
Central PA
Hey guys-
I have a 2003 Ranger Edge - 4.0 - 5 spd.
This morning I fired it up to go to work and the wipers are not working. I turned them on and they went up once and stuck there and now will not move.
The washer sprayer still works, but the wipers do not move automatically when I hit the sprayer switch (as they should) either. So, I'm kind of ruling out the switch.
I had the wipers flipped up so they didn't freeze to the windshield. It is about 10 degrees here now. Could something just be frozen up? After a 1/2 hour drive to work they still are stuck in the up position.
Thanks-
Can you physicly move the wipers? They can freeze in the mechanism (ice gets in there).
Jolly Green
I Salt My Ketchup
755
Central PA
I sure hope that's all it is!
I'm going to check it out when I leave for lunch in a bit.
Thanks!
Jolly Green
I Salt My Ketchup
755
Central PA
All is well! Wipers are moving normally!
It was just ice built up down below the top of the cowl. I couldn't really see it this morning at a glance, and didn't have the time to look closely.
Thanks again!
racsan
4xford
379
15
central ohio
i had the exact same thing happen today, truck hadnt been driven for a few days, we had a real fine snow, then freezing rain, then more snow. the cowl area where the wiper linkage is was filled up with slush, it melted a little and refroze. i heated up some winshield washer fluid and poured into the cowl. thawed it out and works fine now.
