Radio wiring diagram
I need a diagram to make sure I've got this all right before I start.
That's all you need, I'd highly recommend a conversion harness available anywhere so you don't have to hack up the harness. I used the install kit as well but I think you could could unhook the metal tabs on the old radio and drill holes in the new radio. You probably will have to Dremel/File down the plastic around the radio for it to fit if you use the install kit. The install doctor says to only do it on the top but that's BS, I did that and i had to wedge it in there. I still need to clean that up.
http://www.installdr.com/InstallDocs/FLM/PDF/356029.pdf
Ridgerunner
573
Stillwater Ok
Didn't you get one with the radio? Also 31 is right a install kit will help you get your new radio in and keep it from falling out.
