Problem with the lights
tanman722001
Not A Chevy Man
Hi Guys,This is on my dads truck.Will try to explain.When youturn the lights on you have to pull switch all the way out and push it back in alittle to get all the lights to come on.I have changed light switch twice and no change.Any one have a clue what to do?Thanks
radialarm
Clown of Death!
tanman722001
Not A Chevy Man
Ok let me try to re explain it.When you pull the light switch all the way out the headlights come on.But the problem is the clearance light doesnt come on until you push the light switch in alittle.Even when you pull the switch to the first notch they dont come on.
radialarm
Clown of Death!
Unless that's a normal function then it has got to be a problem with the switch!!!
The problem you are describing sounds like a switch malfunction as the only component other than wires and bulbs is the high/low beam switch!!!
Check the wiring behind the switch. Could have a knicked wire back there that's moving when you mess with the knob....
