Power window issue
Hello all, I'm new to the site and looking for some info. I have a 2011 F150 and I'm having issues with the rear driver side window. The window will not operate with the front switch at all and will go down but not up with the back switch. I have replaced the window regulator thinking that would solve my problem as I have had this issue in another truck and that worked that time. This time however it didn't fix it. After that didn't work I thought I had a bad switch, so I swapped my switch panel out with my brothers on his truck (2014 F150) and my switch panel worked on his like normal so I put his on my truck and had the same problem. So now I'm thinking it's a wire issue somewhere. Any help will be appreciated, thanks.
I've seen the same problems on non ford products. One was caused by a pinched wire in the door and the other problem was solved by hitting a pothole. Switches worked after hitting the pothole.
3,291
188
In my own world
Doug has it, the wires usually rub together in the door where it goes into the jamb. you need to unhook them, pull them out, repair, and put back
