Beachbumcook
Kansas Chapter member
Here is a TSB for the condition below.
I do not suffer from this issue, but would like to clean/filtert my P/S fluid and then flush it with new fluid (want to get any sediment out that may be present)?
2003-07 trucks grabbing brakes, pedal kickback:
This may be caused by power steering fluid contamination in the hydroboost system. There is a procedure for installing a temporary filter between the power steering pump and cooler to clean the system. After the cleaning procedure is complete and no brake grabbing or excessive steering effort is felt, remove and discard the filter. If brake grabbing continues, replace the hydroboost unit. Filter P/N XC3Z-7B155-BA; TSB# 99-25-8, 7-11-10
QUESTIONS I HAVE:
1) What is cost of this temporary filter at the dealer (if I buy it)?
2) How long does one leave "in-line" - want it to filter, but not become clogged... maybe use two filters over 1 or 2 days time?
3) What does the dealer charge to do this service (parts & labor) or can I do it at home one afternoon (I suspect I can)?
I have replaced my fluid by sucking it out with a basting bulb and re-filling (several times over several days).. so my fluid is OK, but concerned that sediment is in the system and not moving around unless under pressure... in which an in-line filter would be the best solution!!!
QUESTIONS I HAVE:
