Power door questions ???
crzybil87
C.R.A.Z.Y.B.I.L.L
Ive just aquired some power doors (actually saved them from being scrapped) and my truck now has manual doors, my trucks an 89 f250, is there any modules under the dash for the power windows and locks? Or is it just wiring from one door to another?
Lost
PA Chapter leader
3,288
central PA
Been awhile There r plugs on drivers side you need harness that runs to other side of truck (If its not there ) Several I converted did not have harness.
3,291
188
In my own world
Harness goes from door to door. It also goes into the fuse block into two spots.
92 and newer use a cable to open the door latch, not mechanical linkage
crzybil87
C.R.A.Z.Y.B.I.L.L
Do you guys know where I could aquire this Harness? I dont think mine has it
3,291
188
In my own world
Junk yard.The bad part, you have to take the dash out to get it. There is one fastener at the very top, right under the window. Make sure to get the 2 wires into the fuse box, and the circuit breakers
