Plugs and Wires
973
11
I just got a set of wires and some autolite sparkplugs.. going to attempt to do them this weekend..
is there anything i should know before attempting this?? and should i use anti sieze? cause the heads are cast iron anyways, not alum.
radialarm
Clown of Death!
You don't need anti sieze on cast iron heads!!!
Plug wire routeing: Double check to see if this is the correct firing order for your truck!!!
Lost
PA Chapter leader
3,288
central PA
About only issues is routing of wire as if they r wrong can cuase miss. Good luck
973
11
i gutta look at my firing order again.. i know mine is the newer one..
i leaned they changed it cause 7 and 8 were too close together and could blow out a cylinder.. learn sumtin new everyday! lol
