Well, I have a bit of play in my steering. What do you guys think would be the best way to go about fixing it?
Have you checked the tie rod ends etc.?
Both front tie-rods were replaced right before I bought it.
Have you checked them?...as well as the rest of the components for play?
How would I go about doing that. Yes, I know that sounds stupid.
there could be a adjustment screw in the steering box... spin it clock wise just a half turn or so and see if that helps.
This will generally only bandaid the problem. The steering will loosen back up soon after and when it does, it'll be worse than before you tightened the adjuster.there could be a adjustment screw in the steering box... spin it clock wise just a half turn or so and see if that helps.
I've come to learn that these gen 8-9 F150s (150's specifically) just plain have sloppy steering. It's unfortunate but true... Changed my tie rods to all Moog parts (did it myself), had it aligned and it was still sloppy on the way home.
It's an inch or two loose, which seems like it's pretty normal.My first question is what are you considering sloppy? While I agree with Chris that some sterring systems seem tighter than others, are you considering your system sloppy to the standard? Or you have a 1/4 turn of play in the wheel?
I'm with everyone else, don't even touch or look at the steering box, IMO...if it needs adjusting, it needs replacing, and you can do more harm than good 'fiddling' with it.
Start with what Duncan said, there are several joints and links and doo-hickies that might have play in them, starting just behind the steering wheel, all the way down to the knuckle area. It may or may not be obvious what part needs replacing either, it may be a culmination of a bunch of little issues.
And if it is your steering box that's the issue, I wouldn't even look at something you could get from a chain store, my first choices would be some place like Lares Corporation or Red-Head Steering.
Oh god here we go again...Yeah thats normal id get a steering stabilizer for it to take up some of it.
Oh crap! I have some play in the steering of my '94 F150 XLT. I took it to the Firestone dealer and got a lifetime alignment because my steering was pulling a little bit to one side and the wheel was not straight. When I got it back, the wheel was still not straight, the truck still pulls to one side and the steering wheel had some play.
They tried to sell me a "front wheel bearing packing" job claiming that this would fix the play, I think they wanted to lighten my wallet by about $140!. Of course, that sounds completely ridiculous so I did not do it. I thought maybe after I corrected the play I would take it back and have them align it again. Of course, I don't trust them worth a s**t anymore and I think I just lost the money I paid them.
Anyways, I talked to some folks and they suggested tightening the screw in the steering box. I was a little leery but I did it anyway. It was not easy and it's kind of scary because it's hard to say how much you are really turning it... I think I turned it about 1/8-1/4 of a turn and it *might* have taken just a smidgen out of the looseness. Do you guys think I screwed up?
BTW, my truck only has about 78K miles.
