- 973
- 11
so its a blistering 7 degrees here right now and i have no flipping heat in the truck.. used to be pretty decent..
possible its the thermostat?
On the heater hose? I have factory ac and I've never noticed that valve... And I just changed my coolant last weekend.I don't know about his year truck, but isn't there a small vacuumed power valve in the hot coolant line going to the heater core?
The vans (88 E150) have them and some large cars (71 Fords).On the heater hose? I have factory ac and I've never noticed that valve... And I just changed my coolant last weekend.
Which blend door is that Bill? I thought all the blend doors were vac controlled in my truck...The vans (88 E150) have them and some large cars (71 Fords).
They give you a little extra cooling in the large passenger compartments.
NeXtras:
Make sure the Blend door is going all the way and nothing is the way of it like a pencil or pen that dropped down from the defrost vents.
The Blend door is cable controlled and not vacuum.
That is not a blend door, the one with the white vacuum line under the hood is the outside/inside air door.Bill I'm absolutely positive that both of those blower motors have vac lines running to them. I know the one on the blower motor has a vac line because I had to repair it.
The vent-to-floor is not a blend door, it is the Floor/Defrost Door.And I know the blend door under the dash is vac operated because my damned air switches from vent-to-floor when I load up the engine![]()
