no compression
JerseyMudIsFun
Gio in Dirty Jersey
#2 cylinder has no compression
could it be a valve seal ?
It could be anything... Symptoms?
How's your oil pressure?
My bronks old motor had no compression and a part of the exhaust valve broke on cyl #2. Pull the heads and see, if you dont see anything then its prob rings.
No, my bronk didnt get any better with oil, with the valve missing I still had no compression. A wet test will show if you have bad rings. If you add oil, an it goes up, chances are the rings.
Exactly, that's what I'm saying. If you do the dry test and have no compression, then you do the wet and no improvement, it's more than likely valves. If the compression jumps up/improves, it's rings.
JerseyMudIsFun
Gio in Dirty Jersey
now lets all tell the boss, i need another 6k for another engine
her answer will be either, i'm smoking crack or sell it...............lolol
sounds like either way i have another motor to break down
an if i do it once, its gonna be done right, cause i wont wanna do it again
blue smoke out of exhaust, an oil blowing up thru breather
