New 1967 F-250 restorer
lrv
Hello All,
New to the forum here.
Restoring a 1967 F-250 and running into the proportioning block issue. I believe I've gotten the correct part numbers, is there a place anywhere, that I can order this part and others which, I no doubt will need in the future.
Thanks
460Trucker
Has the Cat Scratch Fever
2,153
54
Road Salt Hell
ezernut9mm
pretty sure discs weren't available on the 67's yet. it should just be a distribution block. two lines in and three lines out.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Welcome to FTF
The valves (and the low brake fluid warning lamp switch-that threads into it) are 1967 only.
C7TZ-2B257-E .. Brake Pressure Differential Proportioning Valve / Obsolete
Applications: 1967 F100/250 2WD & F350.
C7TZ-2B257-D .. Brake Pressure Differential Proportioning Valve / Obsolete
Application: 1967 F250 4WD.
C7AZ-2B264-A .. Low Brake Fluid Warning Lamp Switch.
Applications: ALL 1967 Passenger Cars/Trucks/Bronco's/Econolines.
Which one of these valves do you need?
