Cool, thanks, Evan!They are rated @ 8000 lbs.
I have that type of bumper on my truck and it has a sticker stating 8000 lbs max.
Cool, thanks, Evan!
Hey Dennis, got the curb-to-curb on my '91 Bronco by any chance?
(and cab height too, while you're at it?
OP, can we turn this into a "specs thread"?
Butthead in AZ
Butthead in AZ
OK gentlemen, here is what I've found out. The bumper itself is *not* a towing member in my case. You might want to make sure of your particular application, but in my case the truck is equipped with an optional step bumper, which is in effect a towing package.
According to the owners manual, the step bumper hitch is rated at 5,000 lb. It's a formed 5/16" thick (approx) steel box and it's secured to the frame with pretty large metric bolts class 9.8 which means they are medium carbon heat treated bolts with 130,000 psi ultimate strength.
Here are some pictures of the manual page where the tow hitch rating is listed. In a previous page the GCWR (gross combined weight rating) is listed as 11,000 lbs for my particular truck ('94 XLT extended cab, 6' bed, 5.0 with A/T). Also there are pictures of the actual tow hitch which is only nominally part of the bumper itself. I did not see a sticker, but I did not look everywhere yet.
Me...I'd pick up a 2" receiver hitch for a couple hundred bucks and bolt it on in a couple hours.
If nothing else, those bumpers are way too high for most trailers. Even my little baby 2wd Ranger, the bumper was a little on the high side for most standard utility trailers.
x2How far are you moving it and what kind of setting?
City highway back roads?
x2
How many times ya gonna try to jerk the frame out from under the car?
Etc.
I towed a 1957 8x45 "travel" trailer with my '75's bumper, three times.
2+5/16" ball, no bent plates and didn't even "scoot" the plates and no,
they were-not resting down against the bolts.
5000 pound rating?
8000 pound rating?
...as if that's all it can take! LOL
Butthead in AZ
Its your personal call, but the "hitch" is rated for it. The car wont put 5k of pressure on the hitch. Heck i doubt the car itself weighs 5k.
