I was wondering if anyone knew how to adjust the fuel pump in a 93 f250 7.3 idi
Oct 30, 2010 #1 Bigbillf25030 I was wondering if anyone knew how to adjust the fuel pump in a 93 f250 7.3 idi
Oct 31, 2010 Moderator #2 FellroModeratorStaff member7,953361 Iowa County, Iowa Which way are you wanting to adjust? Fuel screw or timing? fuel screw: I find it easier to remove the cover on the timing cover (2 bolts) to be able to see the bolts and lineup pin in the timing gear so you can see when it is top dead center. This guy does an excellent job explaining things about how to do it, so I will let him tell you.... http://www.members.shaw.ca/k2pilot/Injection pump adjustment article.htm
