- 55
Hello Gang, im working on my 79 f 250 4x4.bought it at a local swap meet with no motor or trans in it & the dash was completly dissasembled.from the engine ID tag it had a 351m with a c-6.in the bed of the truck was a 460 out of a van & c-6 case along with related parts to perform the swap with very little cost to complete. in short i rebuilt the engine & trans & it is back in the truck.that was the easy part.my prolblem is this. im attempting to start the vehicle with the key & i get nothing.i have power with the key on to all fuses & assecories & i believe ive narrowed it down to the nss.but i cannot find the feed wires in the wiring harness.the switch is trans mounted with 4 leads on a harness with blade type connectors. to make sure this was correct i checked my steering column for a column mounted switch & there are no provisions for this type of switch,or any connector off the wiring harness in the dash,now since im peiceing this truck together i did not recieve all the column linkage to the trans & in short ive installed a B&M truck mega shifter on the floor.to accomodate the shifter linkage, the factory nss had to be removed from the trans.the shifter has nss & backup light capability but as i stated i cannot find the feed wires.the truck will start by using a remote starter button at the selenoid & with the key on.since the truck was dissasembled when i got it.im not sure if part of the harness was removed & im pretty weak at making sense of wiring diagrams.any help would be greatly appreciated.
lol Thanks Bob
