my new posi axle!! 56K arning
surewhynot
Rep whores make me sick
13,843
821
Florida
By definition a limited slip is a positive traction device. Posi is a chevrolet term to describe a limited slip clutch style differential, the exact same thing as a ford limited slip. There is NO difference. Lets keep this thread civil or it will be locked.
973
11
Thank you!
Travis, you have any pics of the carrier?.. im thinking of finding a LSD rear end now..
another question.. because your changing the front to LS.. do you have to change the front one out as well?
106
Now that I think about it, the clutch style diff that I saw that was engaged full time but slipped around corners may not have been a real "posi" since it technically wasn't a GM product, but rather aftermarket. So as far as terminology I believe I was wrong. At the time I had it confused with something else.
surewhynot
13,843
821
Florida
A clutch style limited slip differential works by friction from the clutches. There is a set amount of pre load that decides the amount of torque it takes to break the friction and allow one side to spin independently of the other. All clutch style differentials work this way. There is only one exception. That is an aftermarket unit that is a clutch style LS that also has an electric device that locks both sides mechanically, essentially giving the smae qualities as a spool.
flareside_thunder
7,812
246
Also known as a selectable locker or selectable locking differential. 'smiliepig'
surewhynot
13,843
821
Florida
Exactly right. I can't remember who is making the selectable locker with the limited slip feature though. Most selectable lockers are either locker or open.
polarbear
just growing older not up
12,878
607
Boring, Oregon
FYI, an Eaton locker is what Chebbie + GMC use on their trucks. Posi (LS) is a Rear-wheel drive car application only in GM-land. These days, that means Corvette or Pontiac G8. The upside to the locker is both wheels spin together when engaged- it's more effective. The downside is "chatter" when making hard left or right turns, and they have been known to grenade in strenuous use.
973
11
gotta love chebbie! lol nahhht
thats y i stick with ford!
106
Now I know what I was thinking of.
Limited slip that performs open untill needed. Not a clutch, set up though.
http://www.eaton.com/EatonCom/Produ...ducts/Differentials/DetroitTruetrac/index.htm
A POSI that functions as you describe, and the POSI that I was thinking of. This one is NOT open till needed, but rather preloaded at all times with a central spring. This falls under their LSD category too.
http://www.eaton.com/EatonCom/Produ...ucts/Products/Differentials/PosiLSD/index.htm
Also, the e-locker performs open till the user decides to lock it. So, no clutches there.
89frankenford
Grabber Green Consultant
4,547
147
NH
thanks everyone for the help. i plan on replacing the the ring gear and the clutches. i posted some pictures of the ring gear. neither the ring gear nor the pinion gear looked bad at all (minus the chip in the ring gear) would it be bad for me to just replace the ring gear and just keep the pinion untouched?
Replace them both at the same time. They "wear into" each other.
flareside_thunder
7,812
246
exactly...that's like pulling an engine apart and not marking where the rods,wristpins, and pistons go....you just DON'T do it unless you REEEEEALLY wanna take it back apart.
89frankenford
4,547
147
NH
yeah im going to replace both the ring and pinion in a set. wow this thing is going to be fricken awesome!! im also looking to buy a rock guard from bronco graveyard. it looks sick. ill try and find a picture of it tomorrow.
