My electric fan converstion
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
got a good deal on
2 12" 80W fans ( i think they flow about 1500 cfm each no idea does any one know?? how much 12' fans 80w flows?
here is a few pics
just happend to found a perfect piece of stainles in the back yard and perfect size
it was a door to something lol! 'smiliepig3'
27x17 Rad core is 28 x 19
washed
test fit
cutting
final product
all i gotta do is make mounting brackets and bolts the fan to it and wire it :)
3,291
188
In my own world
Nice Job!
You may want to get a controller from summit or Jeggs. That way the fans come on and off automatically at a temp you preset.
The controller also kicks one or both fans on when the a/c switch comes on. Putting electric fans on my truck made a big difference
F 150Cobra
3,642
104
Aruba
Nice Job!
thanks!
i think im gonna do that get a controller with a thermostat
no a/c here buddy :)
That looks good Jurg
F 150Cobra
3,642
104
Aruba
thanks guys its almost done its mounted and tomorrow wireing!!
till now it works i wired it directly and drove around for a while and it keeps it cool
this is what im gonna do
will take another pic tomorrow fully mounted
instead of Thermostat wich i dont have now i will use a switch inside the cab
F 150Cobra
3,642
104
Aruba
Works good till now holds temp fine :)
F 150Cobra
3,642
104
Aruba
I still don't know if I should do this on my truck after I go 3G alternator swap..
the reason i did it becuase know the stock fan wont spin to 7000 rpm on the other engine otherwise i didnt bother
but it feels nice to have it engine responds allot more faster and feels a little faster aswell
primetime
sawmill slave
1,495
64
Onaway Michigan
Do it. Go get some Windstar fans from the junk yard, and throw them in there. The part I absolutely love about mine is how quickly it starts making heat in the cab when it`s cold out side. I will say this though, don`t cheap out on the controller. I`ve killed two Flex-A-Lite controllers and am going to step up to something a little better.
I didn't know people sold fan controllers! Hmm....
Most people won't buy them, they are not cheap.
The Hayden 3647 works well as well, but is a very basic controller....and under $40 is very affordable.
That takes up to a 30 amp draw. So what size fuse would you use?
30 amp continuous would dictate a 40 amp fuse...fuses are 80% rated at a continuous load...wiring would be need to support that load as well.
