mis firing problem
jager420
gotta love an old ford
38
peabody,ma
My 1989 f150 xlt lariat 4.9 straight 6 is having a terrible misfiring problem it can not maintain a constant idle and the engine shakes bad, I just redid the plugs, changed em all with performance plugs and it did nothing to help the problem, what would this problem be, a vacuum leak maybe? I'm an amateur mechanic so any help will be greatly appreciated, I wanna keep the frankenford alive
Might I suggest cap and wires? In the dark, while its running, spray a fine mist of water on everything. The fire flying should point you in the right direction.
jager420
38
peabody,ma
The distributor cap is in good condition , how much to replace that,caps and wires
I would suggest replacing the cap, rotor, and wires as well. When you say cap is in good condition did you take it off and check inside?
flareside_thunder
7,812
246
Nope, a bad distributor cap can cause all kinds of issues....I had one awhile back in my truck that "tracked" all over the place...my truck ran like crap till i replaced it.
jager420
38
peabody,ma
So I changed my distributor cap and rotar and all new plugs and wires and yet the misfiring still continues, any hints from here?
Do you have the wires in the right order? Check your firing order. Maybe 2 of the wires are mixed up. I've done it a few times.
jager420
38
peabody,ma
I did that a few times but I looked up the firing order " 1-5-3-6-2-4, and replaced the wires with deelectric grease and it still does it, could it possibly be the idle air control valve or some thing to do with the vacuum system?or maybe even piston work?
Possibly a bad fuel injector.
jager420
38
peabody,ma
I thought of that , I used lucas oil and other injector cleaners to no prevail, idk much about engines I'm kinda learning as I go, is there only one fuel injector and how hard is it to replace?
