Lowering on the Cheap
flareside_thunder
7,812
246
My buddy's dad builds his own racecars and had a camber gauge.....I honestly think it could have used a 3.5 degree but as long as you keep the tires rotated, you're golden.
Ridgerunner
573
Stillwater Ok
Sweet!!!! One project before I can lower it. That is rebuild my AOD :headbang:
flareside_thunder
7,812
246
You can, and that is initially how I was going to do it, but the bumpstops were firmly planted on the axle.....no suspension movement whatsoever.
That won't do. I imagine that makes the frame weaker.
Morning Cliff :) they make C-notch brackets to reinforce the frame after cutting. The best out there is BellTech. Once installed properly, there is no weak spot in the frame, the only thing is you will always have to have the brackets there even if you decide to go back to stock. You only need to notch the frame if you go more than 4"-5". You can use shackles to get a 2" drop for the rear, and 2"shorter coils for the front. You can also get shorter bump stops. Really have to decide how much drop you want, how much hauling function you still need, and of course your budget. Try sourcing out DJM, they have great drops at a budget price. Let me know how you make out, I did a 3/5 drop on one of my trucks with all BellTech components. Coils and drop spindles for the front, and shackles and drop leafs for the rear. Street Scene drop shocks to finish it off. Was pricey but the way COOL factor is awesome, and it really does make your truck handle like it's on rails!!
Ridgerunner
573
Stillwater Ok
Good idea? Bad idea?
If it says 1" to 2" drop, is that really to be expected?
I'd like to cheaply flatten out the stance on my 81'
I bought the lowering shackles from O'Reillys for my 85 that I had it did more to level it than lower it. I also had to modify the bed frame for it to work. If you want to lower your truck it would be better to order a kit from Summit.
