locked up straight 6
If it was running, and then parked, it for the most part should be ok to just put some good penetrant oil in, not WD40, that really isn't a good penetrant. Check to see if there was any water when you pull the plugs to put oil in. It may be just a light rust that is hanging it up. You can bar the motor over by putting a socket on the crank.
Use good old fashioned motor oil in the plug holes. Take a little care not to completely saturate the plug hole threads with oil. It won't hurt anything, but it's not ideal to replace plugs that are totally lubricated.
Do you think it will crank on its own?
I would just pull the plugs, use a decent funnel, oil it up with like Ryan said, motor oil or maybe a little thinner like atf or Marvel oil. If it is a manual you might try tugging it a little while in gear. Hopefully no water went down the intake while it was sitting.
