Lift Kit
Storm
Registered User
1,320
32
Round Rock, TX
Dont have forum for Lift Kits.. least I didnt see one..
Running DR 4.5" Hanger Lift, Eagle 16x10 and BFG 35x12.50 tires.. I got a vib from 60-70mph.. I think is Driveline Shim issue.. Havent checked it but my question is.. If my shims aren't right and I'm picking up that vib.. Is it enough to make the front shake as well? Wasn't sure if the harmonic vibration would radiate throughout the truck..
At high speed my front end feels funny..
Kep4
Jäger
503
32
Kalifornia
A driveline issue could make the whole truck shake. Sometimes a harmonic vibration can start which will seem to reverberate throughout the truck! Not fun at all.
The front end feeling could be several different things or a combination:
Improper alignment
Out-of-balance tires/wheels
Loose steering box adjustment or steering components
Warped rotors (though you just replaced yours, right?)
Improper tire psi
Overall vibration:
U-joints failing
Tire/wheel balance
The carrier shim as you stated
Pinion bearing failing
Brake rotor problem
Driveshaft out-of-balance (got whacked on a rock for instance)
Hopefully this helps with some ideas to get your PSD vibration free!
Bob Ayers
North Carolina Chapter member
1,474
111
Durham, NC
I hate to say it, but the problems you are having are great reasons NOT to install a lift kit (besides voiding the manufacturer's warranty)!!!
You need to make sure your angle from the transfer case to the drive line is within 5 degrees of the angle from rear end to drive line. Drive line should be straight. That could be your problem. I lift everything I buy. GO BIG OR GO HOME.....
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
I always heard "Lift em up boys, Fat chicks can't climb!" LMAO
There have been several today!
What's old is new again. Honestly though, unless it's a regularly covered topic, I don't mind.
Yeah...but you are the supreme post whore :D smilietease
I see you recognized my motive, in that it allows me to post even more. Blasted, my fool proof plan has been foiled again.
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
Useless thread revive, Storm (Superduty Lifted with stacks) has now been reduced to no more than a Mist. (audi , or was that an inny)
