Lets do this another way!
Do you hear it when your on the throttle or when coasting/compression braking?
Does it make the noise while going straight or on a turn?
Braking or throttle makes no difference. Its more evident when turning.
Simple; the fender liner is loose. :D
Hear the noise every time you hit those speeds or hit and miss?
When and where was the vehicle last serviced and what was done ?
Its kind of intermittent at those speeds. You do the regular maintenance (if its not been done well, the customer will sue you)
Noise is coming from the rear?
And more so when turning?
