IVE HAD IT with this clutch system and manual gearbox!!
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
new master cylinder... the pedal has some power to it like normal but nomather what i do i wont go into gear!!! we bled it like a 100 times no air whatsoever in the system and its still bad!! clutch has the resistance like normal but the clutch down there only move about 0.5 cm what the heck is wrong here??
the slave cyl is also new!!
(on the side note what does a slave cyl does when it goes bad?)
im sooo tired of this i have a C6 lying around im gonna rebuild it and put it in the truck!!
what could be the problem here??
Get a dent. no hydrolics
Agreed
Only problem I see with swapping in the C6 Jurg is...is it a small block C6? If not, you need to find the right bell housing.
F 150Cobra
3,642
104
Aruba
Agreed
yes its a smellbousing c6 but im looking for a c4 less power rob
My bet is that you've still got air in the master.
I can't remember if those trucks are set up quite as stupid as the Ranger, but I know on my truck you can bleed it forever and it won't get all the air out.
I ended up effectively bench-bleeding it with it installed in the truck, which worked but was a huge PITA. Basically take the MC apart until you can pull the piston far enough out for fluid to escape (repeatedly) then bleed the system normally.
*Disclaimer- I'm a Ranger guy. I only know a little tiny bit about the full-size trucks. This *may* not apply.
F 150Cobra
3,642
104
Aruba
i think it has air in the system.. tomorrow a friend is gonna help me try a few technique if it wont work ill buy a C4 already found one for 250$
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
bad slave....
F 150Cobra
3,642
104
Aruba
bad slave....
how sure are you??
it happend like this
the clutch slowly starting to crab closer by the floor.. then it got worst that it started moving when clutch fully engaged now its so bad that it wont go into gear!
blackhat620
You Had to be There
1,687
150
Arizona
Jerg, they are the worse to bleed out. Took me longer on an 92 F350 with a ZF then I did to do the job. You have to get the front really high, or take the slave off and point it up, thats what the procedure tells you to do.
F 150Cobra
3,642
104
Aruba
im gonna try a trick an old guy tought me today.. he said insert a hose thru the bleeder.. open bleeder and open master cyl cap up there.. and then push with a pump brake fluid thru the bleeder at the trans to the master up top.. seems like a good idea where gonna try it!
the slave is in the trans :(
Oh, thats for the external 1, if possible get a reverse bleeder, it pushis the air to the top, where the air wants to go to begin with.
F 150Cobra
3,642
104
Aruba
thats what where doing.. but redneck style..
blackhat620
You Had to be There
1,687
150
Arizona
Actuallly, not redneck at all. The "reverse fluid" injection bleeding technique has been around for quite a long time. Some ABS systems must be reverse fluid bled to service properly. Phoenix Systems probably make the best injection/vacuum tool on the market.
www.brakebleeder.com/index.php?main_page=company
Also you may want to bench bleed you maste cylinder if it did not come pre-bled.
F 150Cobra
3,642
104
Aruba
i did blench bleed it i think.
put fluid in it and pump it??
